audiovox
bluegold
Member - Posts: 7
Posted: June 08, 2012 at 6:50 PM / IP Logged
I currently have a Audiovox  Pursuit Pro-9675FT4 installed in my van. Can I remove the Pro-9675FT4 and install a model APS 996A Informer series with a minium amount of re-wiring? If so what changes would I have to make? And is it worth the change?
Thanks for ther help,
bluegold
racerjames76
Silver - Posts: 581
Posted: June 09, 2012 at 8:25 AM / IP Logged
Not sure if the 9675 has alarm built in, but the main differences are the plugs.
The 6 pin main harness should be the same. The bypass if present can be used. You may have to find door triggers, horn, siren, and mount the LED and shock sensor.
Not a huge job, but you may find it easier to just remove and start over.
bluegold
Member - Posts: 7
Posted: June 09, 2012 at 10:14 AM / IP Logged
Thank you very much for the information.
bluegold
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
