94 mustang 460 replacement
qtownhb
Posted: December 27, 2012 at 9:27 PM / IP Logged
I'm replacing the head unit on my 1994 Ford Mustang with the Mach 460 system.
I got a new sony head unit and the wiring harness. When I plugged it in, it worked, but the amps did not come on. So I put the old stock stereo in and still no amp (you have to turn it alll the way up to get sound).
I assume I did something to kill the amp. Not sure what to do now. Neither the old nor the new stereo work now.
I checked every fuse under the hood and under the steering wheel with a meter and visually.
Thoughts???
DYohn
Platinum - Posts: 10,741
Posted: December 28, 2012 at 12:51 PM / IP Logged
Which wiring harness did you use?
qtownhb
Posted: December 28, 2012 at 12:58 PM / IP Logged
I got one from Crutchfield
http://www.crutchfield.com/p_120705510/Receiver-Wiring-Harness.html?tp=2977
DYohn
Posted: December 28, 2012 at 1:07 PM / IP Logged
OK, that harness can allow the +12V turn-on signal from your new head unit to reach the OEM amplifier when it only needs a +5V signal, so it is possible you blew the remote on circuit in the amp. Did it pop the first time you turned it on? I don't recall if the amp has a fuse inside it or not... Also, did you disconnect the battery when you installed the system? If not try disconnecting the battery for 5 minutes to reset the system.
