2008 Mazda 3 Alarm/Remote Start Wiring
ncreglos
Posted: February 22, 2013 at 6:40 AM / IP Logged
Can anyone give the wiring diagram or information for 2008 Mazda 3.
I would like to install a 2 way security w/ remote start.
Thanks,
Ncreglos
**o**
offroadzj
Gold - Posts: 2,043
Posted: February 22, 2013 at 9:00 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - MAZDA / MAZDA3 / 2008 / Remote Start
[PRINT THIS PAGE]
12volts      BLACK/ red (30A)      +      ignition switch
Notes: If equipped, the Sirius Satellite Radio is under the top center of the dash.
Starter      gray/black      +      ignition switch
Second Starter      N/A
Ignition      GREEN/ YELLOW      +      ignition switch
Second Ignition      N/A
Third Ignition      N/A
Accessory      pink / YELLOW      +      ignition switch
Second Accessory      yellow      +      ignition switch
Keysense      RED / black      +      ignition key switch
Power Lock      GREEN/ red to BLACK/ blue      -1000 ohms      driver kick or PJB, brown 32 pin plug (J-06), pin T
Notes: The PJB (Passenger Junction Box) is behind the glove box.
Power Unlock      same as power lock      -
Lock Motor      yellow/black      5 wire      driver kick or PJB, 46 pin plug (J-05), pin AP
Unlock Motor      WHITE/ black      5 wire      driver kick or PJB, 46 pin plug (J-05), pin L
Parking Lights+      ORANGE / white (L), orange (R)      +      passenger kick or PJB, 46 pin plug (J-05), pins G and AS
Parking Lights-      BLACK/ white      -      light switch or PJB, 46 pin plug (J-03), pin I
Hazards      BLACK/ orange      -      hazard switch or PJB, blue 32 pin plug (J-04), pin AC
Turn Signal(L)      blue      +      passenger kick or PJB, 46 pin plug (J-05), pin A
Turn Signal(R)      blue/red      +      passenger kick or PJB, 46 pin plug (J-05), pin AK
Reverse Light      GREEN/ orange (4 door), GREEN/ black (5 door)      +      passenger kick or PJB, 46 pin plug (J-05), pin C
Door Trigger      BLACK / YELLOW      - N.C.      driver kick or PJB, brown 32 pin plug (J-06), pin W
Dome Supervision      BLACK/ blue      -      passenger kick or PJB, 46 pin plug (J-05), pin U
Trunk/Hatch Pin      BLACK/ red      -      pass kick or PJB, brn 32 pin plug (J-06), pin Z (4 door) or X (5 door)
Hood Pin      BLACK / YELLOW      - N.C.      hood switch or PJB, green 32 pin plug (J-02), pin Y
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      BLACK/ blue      -      driver kick or PJB, brown 32 pin plug (J-06), pin Y
Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm      BLACK/ white      -      driver kick or PJB, brown 32 pin plug (J-06), pin AA
Disarm No Unlock      use keysense
Tachometer      BLACK/ stripe (non-turbo) or GREEN/ stripe (turbo)      ac      any fuel injector
Wait to start      N/A
Brake Wire      RED / white to RED / yellow      +      brake switch, driver kick, or PJB, 46 pin plug (J-05), pin M
Parking Brake      BLACK/ lt. green      -      parking brake switch or PJB, blue 32 pin plug (J-04), pin AB
Horn Trigger      black      -      horn switch or PJB, blue 32 pin plug (J-04), pin N
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Modules: Not Available
What remote start / alarm unit and bypass are you using?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
ncreglos
Posted: February 22, 2013 at 11:32 AM / IP Logged
Thanks Kenny, this will help me a lot.
**o**
ncreglos
Posted: February 22, 2013 at 11:36 AM / IP Logged
I have a Power Teknique 2 way security system w/ remote and a PKFM platform 4 bypass module. Do you think this will work? Do you have a wiring diagram for installing bypass module. My alarm doesn't have a D2D connection, I guest I will go with W2W, But don't know how to do it.
Thank,
**o**
offroadzj
Gold - Posts: 2,043
Posted: February 22, 2013 at 12:33 PM / IP Logged
I don't have anything for that bypass, but you should be able to find it available either online or from the manufacturer if it did not come with it. I have never installed the Power Teknique so I have no idea about any of those connections etiher.
I prefer to stick with Compustar and iDatalink for all my remote start parts.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
