07 mustang speakers pop
window
Copper - Posts: 56
Posted: March 16, 2013 at 10:38 AM / IP Logged
does anyone know the name of the part that will eliminate the speaker pop when i turn on the radio i know radio shack sells it just dont remember the name of it oh i replaced the factory radio
pentavolvo
Copper - Posts: 241
Posted: March 16, 2013 at 1:29 PM / IP Logged
You need a 5 volt regulator on the turn on line
window
Copper - Posts: 56
Posted: March 16, 2013 at 2:44 PM / IP Logged
thank you
Platinum - Posts: 13,725
Posted: March 17, 2013 at 4:06 AM / IP Logged
Take 2 470 ohm 1/2 watt resistors. Wire them in series. Connect the remote wire from your aftermarket radio to one end of the device. Ground the other end of the device. Connect the factory amp turn on wire to the junction between the 2 resistors. Insulate the device and enjoy pop free audio.
Ravendarat
Platinum - Posts: 2,806
Posted: April 29, 2013 at 12:47 PM / IP Logged
Uh a simple solution is just put a 1k resistor on the remote turn on wire off the deck then hook the other side up to the remote turn on in the vehicle. No more pop
tonanzith
Gold - Posts: 603
Posted: May 02, 2013 at 10:40 PM / IP Logged
1k resistor usually does the trick. Some times I've had to bump it up to 1.5 but eitherbway that always does the trick.
Gary Sather
