18 pin pigtail/harness for thx system
awdonly
Member - Posts: 12
Posted: January 06, 2014 at 2:16 AM / IP Logged
Need help finding correct pigtail please.   2006 Lincoln Navigator with THX system uses an 18 pin connector for most of its speaker outputs (to amp) from head unit in addition to a 24 pin connector.    Able to find pigtail to connect to 24 pin connector ((Metra 70-5520) but having trouble with findng counterpart for 18 pin.  I believe the existing ford connector (the one I'm trying to find a pigtale to mate with) is Motorcraft WPD-279 http://www.amazon.com/Company-Motorcraft-Anti-Theft-Connector-WPT-279/dp/images/B009FXEZ3G
Does anyone know where I can find a female pigtail which would connect to the male WPD-279?
Any help appreciated.
DYohn
Platinum - Posts: 10,741
Posted: January 06, 2014 at 10:32 AM / IP Logged
Are you trying to retain the OEM head? Try Metra kit 71-5520
awdonly
Member - Posts: 12
Posted: January 06, 2014 at 4:12 PM / IP Logged
Nope - replacing head unit, but trying to keep factory amp/wiring.
Ween
Platinum - Posts: 1,368
Posted: January 06, 2014 at 6:58 PM / IP Logged
Hi,
The connectors are manufactured by Molex. They're called 'H-DAC 64
Dual-Row High Density Automotive Connectors'. They do show 18 pin housing with male pins, however they are meant to be mounted to a circuit board. They don't show a housing with wire-type termination for 18 pin applications. If wires were desired, they'd need to be soldered to the header pins and of course insulated.
Hope this helps,
Mark
awdonly
Member - Posts: 12
Posted: January 06, 2014 at 8:34 PM / IP Logged
It does - thanks!
