08 crown vic issues
rls13
Member - Posts: 8
Posted: October 10, 2014 at 4:01 PM / IP Logged Link to Post Post Reply Quote rls13
I just finished installing a Viper 5704v into a 08 Ford Crown Vic.
I hooked the blue (trunk instant trigger -) wire to the brown / white wire at the LCM. Opening the trunk with a key will properly set off the alarm just as it should, however after arming the system, the alarm will go off within 30 minutes or so and say the it was the trunk "zone" that was triggered even though it wasn't. The car is a CVPI so it didn't have the key less entry option, if it makes any difference. I suspect that there is a pulse or something being put out by the car that is triggering the alarm falsely.
I clipped the blue wire and tested to see if the alarm would still get triggered after 15-30 minutes and it doesn't. It has sat for hours with no false alarm. I would like to be able to reattach the wire, but need to know what is causing the false alarm.
Can I diode isolate this trigger to allow the negative pin switch signal to trip the alarm, but not allow whatever else is coming down the line? Or is there just some CVPI trick that is well known and I'm just not finding? There is no other pin switches or sensors connected to the blue wire, only the trunk pin.
Thanks.
Platinum - Posts: 7,791
Posted: October 11, 2014 at 9:33 AM / IP Logged Link to Post Post Reply Quote kreg357
Think you are on the right track with diode isolation.  Check out DEI Tech Tip 1076 :  https://www.the12volt.com/installbay/file.asp?ID=514
rls13
Member - Posts: 8
Posted: October 11, 2014 at 10:10 AM / IP Logged Link to Post Post Reply Quote rls13
Yeah I finally found another post about a 99 Grand Prix on this forum this morning, where the poster had the same issue and was recommended to use the same fix. It sounded like he ended up diode isolating a different wire that had to do with the trunk courtesy light, but with the same results.
I diode isolated the trunk trigger input to the alarm with the cathode away from the alarm box, but again got false triggers.
I don't know if it is the LCM sending the ground pulse or the BCM, and I don't have a good wiring diagram for the car (the Chilton's manual is extremely vague...), so without knowing which module or where the BCM makes its connection in the circuit, the only sure fire way to do what is in that DEI 1076 document, is to run a wire all the way back to the trunk?
Here is an idea I was toying with also. If I could attach images it would be a little easier to explain. I HAVE NOT actually wired this stuff up. It is just a theory.
-Cut Brown / White trunk trigger wire
-Run trigger side to Relay #1 Pin 30 and and Pin 85, plus Relay #2 Pins 30 and 85.
-Run LCM side to Relay #1 Pin 87a(N.C) and Relay #2 Pin 87(N.O)
-Connect fused constant 12VDC (+) to both Relay Pins 86.
-Connect alarm trunk trigger input (-) to Relay #1 Pin 87(N.O)
This seems to allow the BCM and LCM to have a closed connection at all times to the physical trunk trigger, allows the courtesy light to function as normal and isolates the alarm trunk trigger input from the BCM and LCM so that the negative pulse that occurs roughly 30 minutes from arming the alarm, has no effect on it.
Please feel free to check my "math" as I don't claim to be an alarm wiz...
rls13
Member - Posts: 8
Posted: October 11, 2014 at 10:24 AM / IP Logged Link to Post Post Reply Quote rls13
Actually it appears that I can upload pics. I will try anyway.
I also had the thought that could just do away with relay 2 completely and just put a diode between pin 87 and 87a, with the cathode on 87?
Posted: October 11, 2014 at 10:59 AM / IP Logged Link to Post Post Reply Quote kreg357
Perhaps the more direct way is easiest.  Install a separate pin switch in the trunk for the Viper alarm and leave the vehicle wiring alone.  The rust issues should be less in the trunk environment. I have a pot full of the hood pin switches that are included in most R/S kits ( I use mercury switches if the vehicle doesn't have a viable hood pin switch ).  I can send you a couple.  08 crown vic issues - Last Post -- posted image.   Leftovers from recent installs...
rls13
Member - Posts: 8
Posted: October 11, 2014 at 5:29 PM / IP Logged Link to Post Post Reply Quote rls13
I appreciate the offer but I think I am just going to go the diode route that is in the DEI 1076 document. While I was out and about today, it dawned on me that my relay idea will probably not work. Because the negative pulse send from the (I am guessing LCM, since I can't find anything about a BCM on Crown Vic's) will simply find its way back to the alarm by triggering the relay coil since it is tied to it in reverse. Once the coil is energized then it will most likely latch Pin 30 to Pin 87 and then set off the alarm. The only way is to install a diode as Doc. 1076 shows...
So I just went and picked up more.
Thanks for the help.
ensjesse
Posted: September 08, 2015 at 11:05 AM / IP Logged Link to Post Post Reply Quote ensjesse
Thank you for the info! I have a 2010 CVPI and not only does the LCM ground the trunk trigger but also the headlight switch as well. I have them connected to my CS7000 and am getting false inputs on the headlight and trunk warnings after 30 minutes when the battery saver mode kicks in. Only thing that will be a bummer here is I am not really wanting to sever the stock wiring. An alternate trunk trigger may be good as you suggested but what about my headlamp switch? Is there any clean way to insert the diode in path and keep a good connection? I don't have much room to solder around the LCM.
Thanks for the information.
Jesse
Posted: September 08, 2015 at 1:26 PM / IP Logged Link to Post Post Reply Quote howie ll
Tried relays, 10k pullup resistors and diodes, the last is the only effective method.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
