Do speakers and electric motors interfere?
schmokey
Posted: April 11, 2015 at 5:26 PM / IP Logged Link to Post Post Reply Quote schmokey
Hi Folks and hello from Ireland.
I have a question which may be bleeding obvious but I figured I'd ask it anyways as, while I'm pretty mechanically minded, electronics to me are somewhere between voodoo and reiki.
I have a 1988 Land Rover Defender which I'm hoping to build into an expedition/camping vehicle.
I was just about to cut up part of the dash to install a speaker (no stereo was ever in this car before) when I noticed that, even with speaker spacers the back of the speaker would be about 5mm from one of the heating motors.
So my question is : will a large electromagnet so close to an electric motor cause interference? Should I be looking for a different place to put the speakers?
I'd prefer not to end up in a situation where I can have heating or music. (if you've ever been in an old Defender you'll understand why.
thanks for your help!
(I'd imagine I'll be back when it comes time to install the alarm, the central door locks, the auxiliary fusebox and so on)
For every complex problem there is an answer that is clear, simple, and wrong. [H. L. Mencken]
DYohn
Platinum - Posts: 10,741
Posted: April 12, 2015 at 9:27 AM / IP Logged Link to Post Post Reply Quote DYohn
It is possible for an electric motor to cause interference, but generally not directly in a speaker. Much more likely is causing a hum at the frequency of the fan's rotation by inducing a signal into the speaker wire. If you must install the speaker in this location be sure the speaker wire is run in such a way that it is as far from the motor as possible.
schmokey
Posted: April 13, 2015 at 6:52 AM / IP Logged Link to Post Post Reply Quote schmokey
Brilliant!
thanks for confirming that, I didn't think there would be anything delicate in the car but it's nice to have it confirmed.
thanks again
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
