Bass Boost Controller
jeffster1978
Posted: September 06, 2015 at 12:33 PM / IP Logged Link to Post Post Reply Quote jeffster1978
Hey guys! Quick question.....I have two Crescendo 3500 amps. Each one comes with its own bass boost controller to install up front. Can you wire both of them together to utilize only one controller or do I have to install both bass boosts? I have seen a lot of guys with 4 or more amps and only using one bass boost controller. The wires for each controller look like phone type jacks. Thanks for your help!
varietyguy
Posted: November 04, 2015 at 12:22 AM / IP Logged Link to Post Post Reply Quote varietyguy
You can either link both amps together to have a master and slave, then just run 1 controller from the master amp. What most people do is run a pac lc1 which utilizes the rca cables from the head unit and is wired before they get to the amplifiers. Generally a 3ft section from head unit, pac lc1, then remaining distance to amplifers.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
