04 Nissan 350z reverse light wire
rnemtb
Copper - Posts: 70
Posted: November 19, 2015 at 5:02 PM / IP Logged Link to Post Post Reply Quote rnemtb
Good afternoon,
i am installing a pioneer ND-B8 backup camera in an 04 Nissan 350z manual transmission. it is Going to a pioneer AVH-P4400BH headunit.
I need to know what wire color is in kick panel and it's polarity?
anything i can find info wise on is LT/Green. the two LT Green i find are 12v positive and drop voltage whe in reverse gear. also reverse light are not coming on.
Thanks in advance for the help,
   George
rnemtb
Ween
Platinum - Posts: 1,366
Posted: November 19, 2015 at 9:33 PM / IP Logged Link to Post Post Reply Quote Ween
Hi,
Service manual shows orange coming from backup lamp switch, changing to light green at the rear by the lamps.
Posted: November 20, 2015 at 11:41 AM / IP Logged Link to Post Post Reply Quote howie ll
You're at the rear of the vehicle installing your camera, how long would have taken you to pull the light unit, gone to each wire or the nearest connector, park brake on shifter in reverse, ignition on and tested?
You will still have to test Ween's advice even though you can assume it's accurate.
rnemtb
Copper - Posts: 70
Posted: November 20, 2015 at 12:06 PM / IP Logged Link to Post Post Reply Quote rnemtb
light is mounted to bumper.we narrowed it down to bad reverse switch and also a bad camera. thank for all the help
rnemtb
Posted: November 20, 2015 at 12:15 PM / IP Logged Link to Post Post Reply Quote howie ll
OK Those Nissan bumper mounted lights are awful to get at.
I couldn't give you any advice I did reversing aid on a Juke recently, wire colour was GREEN / WHITE.
Ween
Posted: November 20, 2015 at 5:58 PM / IP Logged Link to Post Post Reply Quote Ween
Pulled info from nicoclub.com, they have a link to FSM's.
Posted: November 20, 2015 at 6:04 PM / IP Logged Link to Post Post Reply Quote howie ll
Mine was UK build, seen it before with Japanese, Euro and US Toyota and Honda, changed wire colours.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
