Problems with my car audio
johncranky
Posted: December 09, 2015 at 12:35 AM / IP Logged Link to Post Post Reply Quote johncranky
Hi,
I have a 94 BMW 3 series with an Alpine system. I am having two issues with this audio system. It's the original that came with the car. It has a tape deck and radio only (I am old). Problem 1, when I turn up and down the volume it cuts in and out on the driver side speakers only while adjusting it. Problem 2, when I play tapes it sometimes makes a squealing sound while it's playing. I checked the tape on my home system and it's fine. But not all tapes do it.
Thank you for your help.Problems with my car audio - Last Post -- posted image.
Platinum - Posts: 13,725
Posted: December 09, 2015 at 7:47 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The cutting out is caused by a dirty volume control. They are easily cleaned in the decks of this era. WD-40 sprayed into the openings of the control works wonders. You must take cover off the top of the deck to access the actual control. (Behind the face, do not try to spray it in the knob area)
Is the squeaking sound coming out of the speakers or out of the mechanism?
johncranky
Posted: December 09, 2015 at 11:36 PM / IP Logged Link to Post Post Reply Quote johncranky
Thank you for the reply. I am not sure if I can get the cover off to have access to the volume control. It has security screws.
The squealing is from the speakers and seems to only do it on one or two tapes.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
