2002 f350 diesel remote start
yan7gin
Posted: January 03, 2016 at 11:08 PM / IP Logged Link to Post Post Reply Quote yan7gin
Good day all,
I'm installing a remote starter on my F350 2002 diesel (7.3) and ran into a issue.
the problem i have is i can remote start the truck but the starter stay engage and after maybe 10 sec everything shots down.
the systhem i have is AS-1755 if that can help
bat9905
Copper - Posts: 131
Posted: January 04, 2016 at 12:55 AM / IP Logged Link to Post Post Reply Quote bat9905
Sounds like a tach issue . Did tach program successfully ? I have found these have to use tech to start
bat9905
yan7gin
Posted: January 04, 2016 at 9:39 AM / IP Logged Link to Post Post Reply Quote yan7gin
I plug the tack wire to my green white CTO (clean tach output) by the 4 service wire inside the cab. I did program the TACH and it look like it did program correctly. I will try to reprogram today and take the AC voltage of my CTO
yan7gin
Posted: January 04, 2016 at 4:36 PM / IP Logged Link to Post Post Reply Quote yan7gin
got it figure out.
I did the TACH programing a couple time without success until i use my whisper mode (lower the rpm to make the truck less noisy) and it work.
thanks for your help
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
