Factory SiriusXM antenna
mohpro
Member - Posts: 38
Posted: February 21, 2016 at 3:01 PM / IP Logged Link to Post Post Reply Quote mohpro
I have a 2012 ford fusion. I will be replacing the factory head unit with a kenwood dnn992. I will be using an idatalink maestro rr to keep the steering wheel controls, microsoft sync. The factory head unit has an internal satelitte radio tuner. So obviously, i have to get a new tuner to use with the aftermarket radio. Will i also need a new antenna for the satellite radio or could I use the existing antenna? Im guessing the factory sat. Radio antenna is built into the factory antenna mounted on the roof
mohpro
Member - Posts: 38
Posted: February 21, 2016 at 3:03 PM / IP Logged Link to Post Post Reply Quote mohpro
The other problem is the new head unit only has 1 serial port. So how do i connect both the idatalink maestro and the new sat. Radio tuner
Platinum - Posts: 13,725
Posted: February 21, 2016 at 4:59 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The SiriusXM tuner will plug into a dedicated plug on the back of the radio. It does not connect via usb.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
