507M tilt sensor
tdi200
Member - Posts: 46
Posted: March 10, 2016 at 8:33 AM / IP Logged Link to Post Post Reply Quote tdi200
@howie ll
this is in reference to the old post i had published on October 15, 2015 in regards of my tilt sensor triggering every now on my corolla 2001 and you quoted the following
"if your tilt sensor keeps triggering, make your installer cut the loops. It should also be mounted on a flat surface facing along the Corolla's front rear axis."
can you or anybody please elaborate as my installer did not understand what exactly it means by the LOOPS AND REAR AXIS? should be noted that both the owner and installers English is second language. Please help needed from anyone here.
alarm specs as follow in my corolla 2001
car alarm= viper 5706v
no hood pin,
506T=Glass break sensor (triggers as SENSOR 2 On the remote)
507M=tilt sensor (triggers as HOOD OPEN on the remote)
535T=Auto 4 windows up whenever armed.
trunk pop
no dome light supervision
tdi200
Member - Posts: 46
Posted: March 16, 2016 at 10:43 AM / IP Logged Link to Post Post Reply Quote tdi200
Still waiting on advice about my issue
dman007
Copper - Posts: 106
Posted: October 13, 2016 at 6:29 AM / IP Logged Link to Post Post Reply Quote dman007
The loop in reference is a black wire attached to the sensor. It just loops from the sensor back into the sensor.
Front Rear Axis, just means the sensor needs to be aligned longways front to back.(Parallel with the car)
DTS Performance
St Petersburg, FL
tdi200
Member - Posts: 46
Posted: October 13, 2016 at 7:52 AM / IP Logged Link to Post Post Reply Quote tdi200
dman007,
Thanks for the reply since its been almost 7months from my question, my car had wiring issues and had to take it to a shop and the people there removed the entire alarm system just to find out the cars engine harness was faulty and was causing the car shut down while driving, and they installed me COMPUSTAR PRIME 901 which comes with integrated TILT senso, if you ask me was viper 5706v better i would say yes viper was better than what i have right now
Posted: October 18, 2016 at 4:27 PM / IP Logged Link to Post Post Reply Quote howie ll
Sorry tdi200, just seen this. I'm glad dman007 posted because my reply would have been if your installer doesn't understand he isn't an installer, all I said is actually in the fitting instructions.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
