98 Chrysler sebring convertible, audio
brandenpippins
Posted: March 24, 2016 at 1:04 PM / IP Logged Link to Post Post Reply Quote brandenpippins
I have 98 Chrysler Sebring convertible with stock infinity sound system and I want to keep using the amp but wire in a new radio. How do I go about this, I want to splice my stereo into same harness that my old radio connects to and still use amp. and how do I get amp to work. I also need wire color codes.
Pippins
wirewise
Moderator - Posts: 489
Posted: March 24, 2016 at 3:56 PM / IP Logged Link to Post Post Reply Quote wirewise
Metra 70-1818 harness.
https://www.the12volt.com/installbay/appguide/1998/Chrysler/Sebring.html
~wirewise~
Platinum - Posts: 13,725
Posted: March 24, 2016 at 8:57 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Use the 70-1817. If you use the 1818 you will not be able to reach your desired listening level. Either harness you use you must connect the blue wire of the harness to the blue/white or blue wire of your new deck.
I stock both of those harnesses as well as both for Nissan, 70-7550 and 7551. Neither of the amplified harnesses on those vehicles work properly.
brandenpippins
Posted: March 25, 2016 at 1:20 PM / IP Logged Link to Post Post Reply Quote brandenpippins
So I tried splicing in new radio into my 98 chrylser sebring convertible and it didn't seam to work. Any advice on wire diagram to make amp and new radio work? The stock radio with infinity amp also had a 6 cd changer that I cut out. Is it needed or inportant?
Pippins
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
