Amp with no marking indications hot or ground
mrhavens
Posted: April 10, 2016 at 12:23 AM / IP Logged Link to Post Post Reply Quote mrhavens
American pro bass machine VS1596. The words have rubbed off need to no which is hot or ground hook up please.
Mrhavens
Platinum - Posts: 13,725
Posted: April 10, 2016 at 12:19 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do you have an ohm meter and or the ability to remove the bottom cover of the amplifier? Or a 10 amp fuse that will fit in your power wire?
If the amplifier has fuses mounted to the end plate, those fuses will be electrically connected directly to the positive terminal of the amplifier.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
