2013 Dodge Charger R/T Stereo Wiring
luism21
Member - Posts: 16
Posted: June 21, 2016 at 1:31 PM / IP Logged Link to Post Post Reply Quote luism21
Im installing an amp and subwoofers on a 2013 dodge charger r/t with beats audio system does anyone have the wiring info so i can connect the line out converter.
rs specialist
Copper - Posts: 175
Posted: June 21, 2016 at 6:19 PM / IP Logged Link to Post Post Reply Quote rs specialist
doesn't that vehicle have a factory sub? if so, grab the signal at the OEM sub. If not grab it from the front door woofers.
tonanzith
Gold - Posts: 603
Posted: June 25, 2016 at 11:44 PM / IP Logged Link to Post Post Reply Quote tonanzith
Radio 12V     RED / white     +     radio, white 22 pin plug, pin 12
Radio Ground     BLACK/ lt. green or black     -     radio, white 22 pin plug, pin 1
Radio Ignition     (CAN IHS)
Radio Illumination     (CAN IHS)
Factory Amp Turn-on     (CAN AT)
Power Antenna     N/A
Left Front Speaker (+/-)     gray/purple - gray / YELLOW     +,-     radio, white 22 pin plug, pins 22 - 21
On models with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier under driver dash, black 16 pin plug, pins 8 - 16. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, white 22 pin plug, pins 20 - 9.
Right Front Speaker (+/-)     dk. GREEN/ purple - dk. GREEN/ YELLOW     +,-     radio, white 22 pin plug, pins 11 - 10
On models with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier under driver dash, black 16 pin plug, pins 7 - 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 - 8.
Left Rear Speaker (+/-)     dk. GREEN/ tan - dk. GREEN/ gray     +,-     radio, white 22 pin plug, pins 20 - 19
On models with amplifier, the speaker wires are dk. GREEN/ tan - dk. GREEN/ gray at the amplifier under driver dash, black 16 pin plug, pins 14 - 6. The tweeter wires are gray/dk. blue - dk. blue at the amplifier, black 16 pin plug, pins 13 - 5.
Right Rear Speaker (+/-)     dk. GREEN/ brown - yellow/gray     +,-     radio, white 22 pin plug, pins 9 - 8
On models with amplifier, the speaker wires are dk. GREEN/ brown - yellow/gray at the amplifier under driver dash, black 16 pin plug, pins 3 - 11. The tweeter wires are gray/dk. green - dk. green at the amplifier, black 16 pin plug, pins 4 - 12.
Center Channel (+/-)     gray/brown - gray/orange     +,-     amplifier under driver dash, white 22 pin plug, pins 10 - 21
Subwoofer (+/-)     gry/brn - dk grn/brn (1); gry/wht - dk grn/wht (2)     +,-     amplifier under driver dash, black 16 pin plug, pins 10 - 2; 9 - 1
Aux. Audio Input Left (+/-)     ORANGE / tan - ORANGE / dk. blue (hands free audio)     +,-     radio, white 22 pin plug, pins 14 - 15
Aux. Audio Input Right (+/-)     ORANGE / lt. blu - ORANGE / dk. blu (hands free audio)     +,-     radio, white 22 pin plug, pins 13 - 15
RSE Video (+/-)     dk. GREEN/ orange - dk. GREEN/ gry (rearview camera)     +,-     radio, black 22 pin plug, pins 15 - 16
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Gary Sather
luism21
Member - Posts: 16
Posted: June 27, 2016 at 11:48 AM / IP Logged Link to Post Post Reply Quote luism21
Thank you guys
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
