2015 nissan rougue
ricardoboston
Copper - Posts: 268
Posted: August 05, 2016 at 5:43 PM / IP Logged Link to Post Post Reply Quote ricardoboston
hi i need some info about what i can use to extend the RF on the OEM remotes on this 2015 rougue i planning to have a dball2 and i need make the RF a long range also did some search and i find it XL202 RFTD NOT SURE if it is what i need also don't know it it use anything else like an antenna ?   thank you all
beegbie
Copper - Posts: 341
Posted: August 06, 2016 at 3:41 PM / IP Logged Link to Post Post Reply Quote beegbie
There's no good reliable way to extend the range of a factory remote. The xl202 along with an antenna cable, antenna and remotes allow you to control the remote start with dei remotes.
lurch228
Silver - Posts: 1,338
Posted: August 06, 2016 at 9:27 PM / IP Logged Link to Post Post Reply Quote lurch228
The xl202 can be used with the 6211t/antenna and any of the remotes on this page. http://www.drdetailshop.com/DEI-Super-Code-LE-Responder-Remote-Replacement-Selection.htm or the 7351v/p/x remote if the antenna date code is OK/10D or later.
Or the 6711t can be used with any of the remotes on this page http://www.drdetailshop.com/DEI-LC3-SST-Responder-Remote-Replacement-Selection.htm
ricardoboston
Copper - Posts: 268
Posted: August 07, 2016 at 4:24 PM / IP Logged Link to Post Post Reply Quote ricardoboston
i see ok thank you both for help me again .
lurch228
Posted: August 07, 2016 at 10:29 PM / IP Logged Link to Post Post Reply Quote lurch228
No problem
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
