5902 Outputs
stanward
Copper - Posts: 57
Posted: September 02, 2016 at 2:22 AM / IP Logged Link to Post Post Reply Quote stanward
Hello,
I do not understand the functions of these wires on the 5902 alarm:
H2/11 Flex Relay Control Output
H2/12 Accessory Output
H2/13 Starter Output
H2/14 Ignition 1 Output
Are they all just extra outputs in case one needs additional outputs (utilizing relays for each)?
Thanks,
Stan
lurch228
Silver - Posts: 1,338
Posted: September 02, 2016 at 2:52 AM / IP Logged Link to Post Post Reply Quote lurch228
Yes they are additional low draw negative outputs to control relays or control other devices that need to operate at the same time as the on-board relays. like using the Accessory output to power a relay for a second accessory on vehicles that have 2 ignitions and 2 accessory that need to be powered for remote start, since the flex relay would be used for the second ignition.
stanward
Copper - Posts: 57
Posted: September 02, 2016 at 3:17 AM / IP Logged Link to Post Post Reply Quote stanward
Thank you lurch!
I was also confused when seeing the alarm has a built-in Flex Relay (Ignition 2) and then there is the "Flex Relay Control Output".
lurch228
Posted: September 02, 2016 at 3:27 AM / IP Logged Link to Post Post Reply Quote lurch228
No problem
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
