How to reduce noise in elementary audio circuit
vellywi
Posted: October 29, 2016 at 2:28 AM / IP Logged Link to Post Post Reply Quote vellywi
I wish to hook up the line-out from a digital piano to a surplus 4 ohm 15w speaker unit. I bought a simple Amplifier module and connected it up.
My plan was to roughly assemble the circuit and, if it worked ok, transfer to strip-board with RCA connector for Audio and a DC power socket and some sort of quick connector for speaker cable.
When I play a note on the piano I get a good level of sound from the speaker but the quality is very poor.
I guess I need to use better wiring on the input side of the amp?
Circuit:
How to reduce noise in elementary audio circuit - Last Post -- posted image.
Here's a photo:
Battery: 12V SLA 3.3Ah
Speaker: 4 Ohm 15W
Amplifier: TI amp TAS2552EVM 4.5-12V, 3.5W "Music power", for 4-15 ohm speaker, 40Hz-20kHz,
Source: Line-out 1/4" TR connector (left channel, set to mono).
Pot: 10K Linear
The speaker is a rear satellite speaker unit from an old TV that had 5.1 surround-sound. The speaker enclosure contains two sounders (approx 5" and 1").
The digital piano is powered through a mains adapter (100-240 VAC 0.2A 50-60Hz) connected using a USB cable (5V 1A). It is light so assume switched mode.
Notes sound rather buzzy. There is mains hum in the background.
What steps should I do to improve the quality of the sound?
You are the best.
Platinum - Posts: 13,725
Posted: October 29, 2016 at 8:19 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Get a real amplifier. A car stereo produces 17.5 watts per channel. Your amplifier produces 3.5 watts.
Get a Car stereo with an aux input jack. Run the piano into the aux jack.
conpar
Stock Boy - Posts: 2
Stock Boy spacespace
Posted: October 31, 2016 at 1:02 AM / IP Logged Link to Post Post Reply Quote conpar
An amplifier with Automatic level control may help you out.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
