Speaker + Tweeter issues?
uberslackr`
Posted: January 06, 2017 at 10:22 PM / IP Logged Link to Post Post Reply Quote uberslackr`
I bought some Kicker component speakers, and they sound horrible.
There were so many reviews raving about how good they are, so I went with them.
There is little to no sound coming from the tweeter and all I hear from the 6.5" speaker is vocal. No bass at all. Now I wasn't expecting hard hitting bass, but am I supposed to get nothing at all? Is it typical to not hear anything from the Tweeter?
I have a Pioneer AVH-X5800BHS headunit.
Woofers: 16.5"
Tweeter: 2"
Dome Material: Titanium
Rated Impedance: 4Ω
Power Handling: 60 RMS
Sensitivity 90
Frequency Response: 35-21k Hz
Crossover Point: 4k Hz
Crossover Slope: 12 hi/12 lo
High Frequency Attenuation Level: 0, +3, +6
lurch228
Silver - Posts: 1,338
Posted: January 07, 2017 at 11:51 PM / IP Logged Link to Post Post Reply Quote lurch228
Sounds like the high/low speakers wires to the crossover swapped.
uberslackr`
Posted: January 08, 2017 at 4:46 PM / IP Logged Link to Post Post Reply Quote uberslackr`
The crossover has 2 wires (+/-) for input.
And 4 wires for output.
The 2 wires for the Tweeter have "round" connectors (attached by manufacturer)
The 2 wires for the mid speaker has "flat" connectors (attached by manufacturer)
Would be hard mix up the wires, as they only connect to their matching part (tweeter | mid)
Only one that could be mixed up is the input wires; but I checked them with my volt meter, and the stock car speaker wires are connected to the indicated +/- of the crossover.
I ordered a small amp (RMS 50x4 @ 4ohm) gonna test that to see what happens; if sound doesn't improve just going to return the speakers system.
martinsons
Posted: January 16, 2017 at 2:42 PM / IP Logged Link to Post Post Reply Quote martinsons
What car are they in? WHat was the previous OEM system? I ask as are you going through the OEM wiring that may have an amp/crossover that the signal may be going through so the components are limited before the kicker crossover? try running new wire straight to the crossover????
Platinum - Posts: 13,677
Posted: January 16, 2017 at 5:46 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Are you sure they are Kicker product? Make sure the writing on them does not say Kikers.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
