2011 Toyota Tundra, windows, sunroof, 535t
mgortman
Member - Posts: 6
Posted: January 19, 2017 at 1:02 PM / IP Logged Link to Post Post Reply Quote mgortman
I'm looking for a wiring diagram for Toyota Tundra Windows color code for the front windows and sunroof. I'm installing 535t. The fronts are auto up. thanks
mg
the12volt
Administrator - Posts: 3,955
Posted: January 19, 2017 at 1:33 PM / IP Logged Link to Post Post Reply Quote the12volt
tdbaker021
Copper - Posts: 98
Posted: January 19, 2017 at 6:22 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Left Front Window (Up/Down) lt. green - lt. blue A power window master switch, white 18 pin plug, pins 10, 12 or 3, 4
On vehicles with auto up power windows, the motor is part of the window module, not allowing access to the motor wires.
Right Front Window (Up/Down) yellow - green A driver kick, blue 10 pin plug, pins 9 and 8
Left Rear Window (Up/Down) purple to red - black to beige A driver kick, blue 10 pin plug, pins 6 and 7
Right Rear Window (Up/Down) beige - lt. green A driver kick, blue 17 pin plug, pins 5 and 4
The back power window up/down wires are red - yellow (-) (functions with ignition on only) at the window switch on the dash, white 8 pin plug, pins 6 and 4.
Sun Roof (Open/Close) beige - purple (functions with ignition on only) - moonroof switch, white 14 pin plug, pins 4 and 3
Sun Roof (Limit/Close) N/A posted_image posted_image
Memory Seat 1 pink - seat memory switch, white 4 pin plug, pin 2
Memory Seat 2 beige - seat memory switch, white 4 pin plug, pin 3
mgortman
Member - Posts: 6
Posted: January 19, 2017 at 6:57 PM / IP Logged Link to Post Post Reply Quote mgortman
Thanks guys for the info. I'm looking for more info on the ones that have auto up power windows since the motor is part of the module not allowing access to those wires. If its been done before.
mg
tdbaker021
Copper - Posts: 98
Posted: January 23, 2017 at 8:27 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Per the DEI 535t manual...
"NOTE: Window automation is not recommended on vehicles where the window motor is part of a door
module."
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
