Wiring two amps, rca
whitemike0110
Copper - Posts: 84
Posted: January 30, 2017 at 5:51 PM / IP Logged Link to Post Post Reply Quote whitemike0110
My question is about rcas. My sub amp does not have rca outputs, only input. I have my new speakers and a rf power 400.4. My sub amp is an mmats. But neither have outputs. Should I just use a y split on my current rcas I have running into the trunk? Or can I run two rcas. Any advice or help would be greatly appreciated.
Hello.
the12volt
Administrator - Posts: 3,959
Posted: January 30, 2017 at 6:02 PM / IP Logged Link to Post Post Reply Quote the12volt
You didn't mention what head unit you have. If your head unit only has one set of RCA outputs and your amplifiers have internal crossovers (or if you're using passive crossovers), using RCA Y adapters will work fine. If you head unit has an internal crossover, a dedicated sub "RCA" output, and front and rear "RCA" outputs, I'd run additional RCA's to your amplifer(s) as needed.
Wiring two amps, rca - Last Post -- posted image. the12volt • Support the12volt.com
whitemike0110
Copper - Posts: 84
Posted: January 30, 2017 at 6:32 PM / IP Logged Link to Post Post Reply Quote whitemike0110
Still have stock head unit with loc. So my best bet is probably buy head unit with more outputs and run a new rca. Thanks man that clears this up for me. Although head unit isn't in the budget right now. Is running a splitter okay one amp is mono block, the other is 4 channel. I guess I'll just make sure my crossover and hi/lo pass filters are set right.
Hello.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
