WIring 2013 RX350/Viper4806/ADS-ALCA
wyciwug
Copper - Posts: 156
Posted: February 22, 2017 at 2:07 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello all
I am doing remote start Viper 4806V with ADS-ALCA. Can someone please help me with the wiring? Correct me if I am wrong in anyway, thanks.
Vehicle Information:          2013 RX350
Remote Start Unit:          VIPER 4806V
Bypass Module:          ALCA-ALA
Remote Start 4806v               Vehicle
Connection     Color     Description     Color     Polarity     Location:
     THICK HARNESS
     Red     12v     White     +     under dash fuse
     Red white     12v     White     +     under dash fuse
     Red black     12v     White     +     under dash fuse
     pink     ignition 1     Green     +     power management control ecu
     pink/white     ignition 2     Black     +     power management control ecu
     Accessory 1     Orange     Gray     POSITIVE     power management control ecu
     Starter 1     Violet     Light Green     +     power management control ecu
     starter 2     Pink/black connect to additional relay to power up      black     -     power management control ecu
          the second starter?
     MAIN HARNESS 6-PIN
     Black     Ground     chassis      -     Ground
     Brown     not used
     White     Light Flash Relay PIN 30     Purple     -     Main body ECU
          Do I need to connect this wire and how?
     Orange     not used
     Door lock 3-pin
     Not used as Bypass will do this
     Aux/Shutdown/trigger 24-Pin harness
     1, 2, 3, 4, 5 6, 7, 8     Not used
     9, 11, 12, 14, 15, 16     Not used
     18 19 20 21 22 23 24     Not used
     Blue     factory horn input (use jumper to Negative)     White     -     Harness at Steering column
     BLACK/ white     Ground     chassis ground
     Pink     not used
Idatalink ALCA-ALA               Vehicle
     PURPLE / Black - RX      RX     PINK     DATA     MAIN BODY ECU
     WHITE/ black-SLP     OUTPUT     GREEN     -     STEERING LOCK
     White     GROUND INPUT
     BROWN / RED     CAN H     PURPLE     DATA     OBD II
     BROWN / yellow     Can L     Red     DATA     OBD II
     ORANGE / black     ground input     chassis
     ORANGE / white     Tx     Light Green     Data     MAIN BODY ECU
     Pink     ignition input to Pink Ignition 1 Input on 8-pin Thick Harness
     Blue/Red     Ground
     Blue / YELLOW-PTS     Not used
dcd
Platinum - Posts: 7,789
Posted: February 22, 2017 at 7:46 PM / IP Logged Link to Post Post Reply Quote kreg357
First, you must flash the ADS AL-CA bypass module with the DBI-AL(DL)-TL2 firmware. This will allow 2way D2D communication
between the Viper and the ADS AL-CA.
Next you should down load this ADS AL-CA w/DBI-AL(DL)-TL2 firmware install guide :
https://images.idatalink.com/corporate/Content/Manuals/DL-TL2/DBI-AL(DL)-TL2-EN_20160407.pdf
You will follow the Type 2 install guide to the letter. Please note that it specifically says :
WARNING:
DO NOT CONNECT ANY OTHER
ACCESSORY,IGNITION OR START WIRE
FROM THE REMOTE STARTER TO THE
VEHICLE. THE INTERFACE MODULE
IS HANDLING THE REQUIRED VEHICLE
POWER AND START SEQUENCE FROM
THE PUSH TO START BUTTON CIRCUIT.
Also, be aware that the remote started engine will shutdown when the door is opened. There is no take-over possible with
these PTS Toyota systems.
wyciwug
Copper - Posts: 156
Posted: February 25, 2017 at 9:57 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello Kreg
Where do I get the 12volt wire from the remote start?
Is it the same thich RED wire from heavy gauge? Or from the main 6-pin red wire? These wires already have fuses, do i remove the fuses and change them to 7.5amps?
dcd
wyciwug
Copper - Posts: 156
Posted: March 01, 2017 at 2:18 PM / IP Logged Link to Post Post Reply Quote wyciwug
anyone??
dcd
silvercivicsir
Copper - Posts: 409
Posted: March 01, 2017 at 4:47 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
Yes power all the red thick wires, and the single red in the 6 pin harness.. I would grab power from the fuse box [Thick white wire]
Wednesday, May 22, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
