Using One Switch to Control Multiple Circuits.
marklar65
Member - Posts: 20
Posted: October 08, 2017 at 4:36 PM / IP Logged Link to Post Post Reply Quote marklar65
I need help (preferably via a diagram) with wiring a single 12volt switch to control 3 circuits. I believe using relays would be the safest way to achive best results. I have a concern about the relays being energized while the vehicle is off since it is a motorcycle. Also since I want to turn the circuits off while the vehicle is running I am kinda lost as how to wire correctly. I appreciate your help in advance with solving my issue.
the12volt
Administrator - Posts: 3,955
Posted: October 10, 2017 at 4:12 PM / IP Logged Link to Post Post Reply Quote the12volt
Is the switch you want to use already on the bike and have a 12V+ output? If so, what is it currently being used for?
Do you want all 3 circuits to turn on and off with this switch at the same time? If not, please describe.
What is the total current draw of all 3 circuits combined?
Using One Switch to Control Multiple Circuits. - Last Post -- posted image. the12volt • Support the12volt.com
Platinum - Posts: 13,674
Posted: October 13, 2017 at 4:58 PM / IP Logged Link to Post Post Reply Quote i am an idiot
And would you ever want more than 1 device on at a time?
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
