2002 Honda crv + alca
Member - Posts: 41
Posted: January 08, 2018 at 1:18 AM / IP Logged Link to Post Post Reply Quote 7808
How much is can bus in a 02 crv ? I recently sold my 04 trailblazer and took my cm2000 or whatever compustar remote start and idatalink alca - can i reuse it in the Honda ? Or does it have to be reprogrammed? Or is this car too "dumb" to use the module to control all the locks lights etc..
bogucki
Copper - Posts: 91
Posted: January 08, 2018 at 1:56 AM / IP Logged Link to Post Post Reply Quote bogucki
yes the idatalink alca can be reused in the honda and it will control the door locks and the immobilizer if you have it, if in canada you will have it, if your in the USA you might not have the immobilizer, if you dont have it i would skip the alca and just hardwire everything. i would recommend getting new wires for the alca, can be found on ebay. and it will have to be reflashed for the honda, so you would need a idatalink account and the usb program cable to do so.
boguckialex
7808
Member - Posts: 41
Posted: January 09, 2018 at 6:10 PM / IP Logged Link to Post Post Reply Quote 7808
thank you. i am in the us. its a japan built us model and it does have a antitheft sticker on the window , has the laser cut style key or whatever they are called. so id guess it does have an immobilizer?
i just was not sure how much can be controlled through can bus via the alca , if i have to hard wire each function i might not even bother to install. now im spoiled with these half dozen wire installs
bogucki
Copper - Posts: 91
Posted: January 09, 2018 at 9:03 PM / IP Logged Link to Post Post Reply Quote bogucki
you need to reflash the alca. the alca will only control door locks and the immobilizer
boguckialex
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
