Constant Negative
12vlost
Member - Posts: 44
Posted: April 06, 2018 at 4:33 PM / IP Logged Link to Post Post Reply Quote 12vlost
Hi all.
Need to wire a relay to give a constant negative when a negative is removed?
TIA
wirewise
Moderator - Posts: 489
Posted: April 06, 2018 at 6:52 PM / IP Logged Link to Post Post Reply Quote wirewise
Wire the terminals of an SPDT relay as follows:
85 to 12V+
86 to your switched ground
87a to ground
30 is your constant ground output when your switched ground is turned off/removed
87 not used
~wirewise~ Verify all wiring with your meter before making any connections!
12vlost
Member - Posts: 44
Posted: April 06, 2018 at 6:53 PM / IP Logged Link to Post Post Reply Quote 12vlost
Got it sorted thanks, voltage across the coil, pin 30 ground when ground is removed from the coil pin 87a becomes constant ground.Need to convert a NC pir to NO this works great after lots of googling some crazy schematics hope it helps someone
12vlost
Member - Posts: 44
Posted: April 06, 2018 at 6:54 PM / IP Logged Link to Post Post Reply Quote 12vlost
Thanks wirewise just saw your post after I replied to myself, much appreciated
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
