MB Quart NA540.6 Amp?
raw customs
Member - Posts: 21
Posted: July 16, 2018 at 9:21 AM / IP Logged
First IF I get this amp I will be running only one sub and 4 door speakers.(its used)
My question is, I am looking at the specs and I understand ohms and channels and all that. What I don't get from their spec sheet is what the sub will be pushed at when bridged.
If anyone could be of any help.
Thanks a bunch.
MB Quart NA540.6
MB Quart NA540.6 Amp? - Last Post -- posted image.
Raw Customs Designs
2012 Ram 1500 QC Tradesman
1996 Impala SS
1964 Impala Wagon
MECP certified
the12volt
Administrator - Posts: 3,959
Posted: July 16, 2018 at 9:34 AM / IP Logged
Assuming your subwoofer is a 4 ohm SVC or a 2 ohm DVC subwoofer (voice coils wired in series), and you're only using two channels bridged mono for the subwoofer, then it will be 180 watts at 4 ohms to your subwoofer.
MB Quart NA540.6 Amp? - Last Post -- posted image. the12volt • Support the12volt.com
the12volt
Posted: July 16, 2018 at 9:54 AM / IP Logged
Also, since the amplifier is stable at 2 ohms per channel, if you have a 2 ohm DVC subwoofer, you can wire 1 channel of the amplifier to each coil. It will be 90 watts at 2 ohms per coil or 180 watts total to the subwoofer. So whether you run two channels stereo or bridge mono, it will still be 180 watts total to your subwoofer.
Please tells us about your subwoofer. Is it a SVC or a DVC woofer and what is the impedance of each coil?
raw customs
Member - Posts: 21
Posted: July 16, 2018 at 1:19 PM / IP Logged
I was going to base my sub off the power rating of the amp.
What would be a good sub to run, since it's only 180 watts?
I was hoping for more but its only going in a quad cab 2012 ram 1500. I'm going to build a center console enclosure for it.
Again
Raw Customs Designs
1996 Impala SS
1964 Impala Wagon
MECP certified
the12volt
Posted: July 16, 2018 at 4:01 PM / IP Logged
You have other power options depending on your head unit and your preferences. You could power the rear speakers from your head unit, the front speakers from 2 channels of the amplifier, and the sub with four channels of the amplifier if you use a 4 ohm DVC subwoofer, which would give you 360 watts to the subwoofer.
As far as suggesting a subwoofer, I would first determine the dimensions and internal volume of your enclosure and whether or not your intend to port it, then come back and ask for recommendations in a new thread.
raw customs
Member - Posts: 21
Posted: July 17, 2018 at 5:34 PM / IP Logged
So use channels 3 and 4 bridged for one voice coil and channels 5 and 6 bridged for the other voice coil?
Will die on the enclosure
Thanks a bunch
Bernie
Raw Customs Designs
1996 Impala SS
1964 Impala Wagon
MECP certified
Platinum - Posts: 13,725
Posted: July 17, 2018 at 8:04 PM / IP Logged
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
