Car Antenna Wiring?
nas1966
Posted: August 11, 2018 at 9:14 AM / IP Logged Link to Post Post Reply Quote nas1966
I have a car antenna with red and white wire going into the controller on the antenna ( Relay ? ) a green wire ( with inline fuse ) and the blue wire are mounted on a switch - does anyone has a wiring/hook-up diagram?
Thank you for your help
the12volt
Administrator - Posts: 3,959
Posted: August 12, 2018 at 11:56 AM / IP Logged Link to Post Post Reply Quote the12volt
Is there a brand name on it anywhere? Please post photos.
Car Antenna Wiring? - Last Post -- posted image. the12volt • Support the12volt.com
nas1966
Posted: August 13, 2018 at 2:53 PM / IP Logged Link to Post Post Reply Quote nas1966
It is a SPARKOMATIC Model SA 301 Didnt know how to upload photo tried to "drag in" did not work enter file name dd not work eithet
the12volt
Posted: August 13, 2018 at 3:07 PM / IP Logged Link to Post Post Reply Quote the12volt
To upload images, click on this button Car Antenna Wiring? - Last Post -- posted image. in the toolbar above the new message form.
You have a power antenna. The fused lead should go to a constant 12V+. The base of the antenna needs to be grounded. The blue wire is most likely for for fully automatic mode. Apply 12V+ to this lead will make it go up. Removing it will make it go down. This would connect to the power antenna output of the radio (also usually blue on all aftermarket radios). The other two leads are probably for manual mode and would require an included toggle switch. I would bench test this first before installing it into a vehicle.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
