Wiring Dual 3 Ohm Subwoofer to 1 Ohm?
datexicanz
Posted: August 15, 2018 at 4:11 AM / IP Logged Link to Post Post Reply Quote datexicanz
I have a 12 dual 3ohm subwoofer & i have a Rockville RXD-M2 1ohm amp & how do i wiring up this subwoofer to 1 ohm & here is a link of info on the subwoofer i have http://www.ultimate-sound.com/car/manuals/KW%20Series%20-%20Subwoofers.pdf
datexicanzaudio
the12volt
Administrator - Posts: 3,959
Posted: August 15, 2018 at 11:59 AM / IP Logged Link to Post Post Reply Quote the12volt
You can't wire the 2 coils of a single DVC 3 ohm woofer to get a 1 ohm load. You can wire the coils in parallel to get a 1.5 ohm load, or you can wire them in series to get a 6 ohm load, or you can use just 1 coil for a 3 ohm load. Those are your only wiring options.
https://www.the12volt.com/caraudio/boxcalcs.asp#par
Wiring Dual 3 Ohm Subwoofer to 1 Ohm?  - Last Post -- posted image. the12volt • Support the12volt.com
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
