2008 Jeep J/K Manual Transmission Remote Start
vmd710
Member - Posts: 7
Posted: November 12, 2018 at 11:28 AM / IP Logged Link to Post Post Reply Quote vmd710
Hi everyone, thanks so much for your replies, got a lot of the wiring taken care of. everything works now except in order to get it to start i have to press the clutch down, which makes me believe i need to bypass the clutch, not sure if i can do this with a ground when running wire not he viper/dball or if i need a relay. Any input is as always appreciated!
geepherder
Platinum - Posts: 3,668
Posted: November 12, 2018 at 4:53 PM / IP Logged Link to Post Post Reply Quote geepherder
Set your parking brake and make sure the Jeep is in neutral.
Pull the starter relay. Find terminals 85 and 86. Verify with your meter one of them has constant power and the other does not. Take a length of small gauge wire. Strip it back and wrap it around the other terminal (if 85 has power, wrap your wire around 86). Now, put your relay back in place making sure the other end of the wire does not touch metal or ground. Turn your key to the ignition position without starting the engine. Go back and touch the other end of that wire to ground.
Did the engine start?
If yes, you can run the negative starter wire under the hood to the starter relay.
vmd710
Member - Posts: 7
Posted: November 13, 2018 at 12:03 PM / IP Logged Link to Post Post Reply Quote vmd710
Just wanted to say thanks to everyone for all the help, hit the button and started right up. My first manual and it was an experience but fun none the less. Again, thanks for everything
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
