2012 Honda Pilot Key, 4806V and Idatalink ADS AL DL
wyciwug
Copper - Posts: 156
Posted: December 15, 2018 at 8:59 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello everyone
I am doing this car tomorrow and here is what I will follow on the diagram. Please advise me if I am wrong and what need to be added. Thanks
Installation type #1
REMOTES START 8-PIN
Red/black, red/white and Red 12volt to 12volt WHITE 50Am in car (ign switch)
Pink/Black NC
Pink ignition 1 to ignition PINK in car
Pink/white NC
Violet starter (+) to starter YELLOW in car
Orange (+) accessory to accessory ORANGE in car
Which wire from Remote start I can connect to second accessory RED in car? Is it the #21 VIOLET/BROWN from the remote starter 24-pin harness?
Between Remote start and ADS: I connect using D2D
RS #12 VIOLET/WHITE Tach input to PURPLE/WHITE tach (AC) output in ADS
ON ADS-AL(DL):
white/black ignition to CUT ignition in car at the connector side
White/red igntion to CUT ignition in car at the car side
Brown/Red CANH to CANH in car
Brown/yellow CANL to CANL in car
ORANGE/black Key Data to Data in Car
PINK ignition tap onto PINK in RS
dcd
geepherder
Platinum - Posts: 3,668
Posted: December 16, 2018 at 8:20 AM / IP Logged Link to Post Post Reply Quote geepherder
wyciwug wrote:
REMOTES START 8-PIN
Pink/Black NC
Pink/white NC
Looking at the manual on this site, pin 21 is a violet/yellow negative starter output. Don't use that.
The Pink/white wire from the remote start heavy gauge harness is IGN2 by default but can be programmed to ACC2.
wyciwug
Copper - Posts: 156
Posted: December 16, 2018 at 8:34 AM / IP Logged Link to Post Post Reply Quote wyciwug
thank you very much
can you also point me out which wire from remote start i use to turn off auto headlight after car shut down? thanks
dcd
geepherder
Posted: December 16, 2018 at 10:53 AM / IP Logged Link to Post Post Reply Quote geepherder
I don't know for sure, but you could see if opening the door after remote start shutdown works. If it does, you could pulse the door trigger wire, but you should probably relay isolate it to prevent setting off the Viper.
Alternatively, you may be able to interrupt the headlight wire at the switch during remote start.
wyciwug
Copper - Posts: 156
Posted: December 19, 2018 at 11:35 AM / IP Logged Link to Post Post Reply Quote wyciwug
Hello
I got it working. The bypass did all the job shutting down the light after remote start shut down
dcd
Wednesday, May 22, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
