2011 Ford Fusion Flasher Relay
the duke
Posted: January 12, 2019 at 5:01 PM / IP Logged Link to Post Post Reply Quote the duke
I have a 2011 Ford Fusion SE. Does anybody know where the flasher relay is? I upgraded my turn signal bulbs to LED & they’re hyper flashing. I read that to correct it is to either install load resistors or upgrade the flasher relay to one that’s LED rated. I’m opting for the LED relay upgrade since that’s easy & simple. Looking in my manual, I can’t seem to locate which relay it is & its location. Any help would be appreciated. Thanks in advance. This is a link to what I’m upgrading to.
https://www./itm/12V-3-Pin-LED-Adjustable-Car-Flasher-Flash-Relay-Turn-Signal-Light-Indicator-US/312086598379?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
geepherder
Platinum - Posts: 3,668
Posted: January 12, 2019 at 8:42 PM / IP Logged Link to Post Post Reply Quote geepherder
Your car doesn't use a standard flasher. Turn signals are controlled by the BCM (SJB). See here:
http://www.bbbind.com/free-tsb
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=878462
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=878614
If you wanted to modify the factory harness, you could take the output of the multifunction switch and rewire to your own flashers. Then you'd cut the turn signal wires from the BCM and wire them up.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
