Wanted 998T Bit Writer
itolond
Copper - Posts: 87
Posted: February 02, 2020 at 1:23 AM / IP Logged Link to Post Post Reply Quote itolond
I am after a bitwriter to setup my alarm and reconfigure may alarm. the new series XK would be no use as I have not OBD in the vehicle. Mist that I see are out of stock - where to get even 2nd hand is ok
geepherder
Platinum - Posts: 3,668
Posted: February 02, 2020 at 5:55 AM / IP Logged Link to Post Post Reply Quote geepherder
https://www.portarget.com/products/Directed-Electronics-%252d-Bitwriter.html
You should still be able to use an XK Loader3 if you want. It just uses the connector for power. You just need to put power to pin 16 and ground pin 4:
https://www.google.com/search?q=obd2+pinout&tbm=isch&source=univ&hl=en-US&sa=X&ved=2ahUKEwjolovO5rLnAhVEIqwKHaZYDeoQsAR6BAgKEAE&biw=1101&bih=1651&dpr=3
itolond
Copper - Posts: 87
Posted: February 02, 2020 at 6:45 AM / IP Logged Link to Post Post Reply Quote itolond
for the XK Loader3 don't I need a DEI account or similar?
geepherder
Posted: February 02, 2020 at 6:55 AM / IP Logged Link to Post Post Reply Quote geepherder
Not for just using the bitwriter functions. Other functions will be locked out.
Here's another bitwriter link:
https://www.drdetailshop.com/998T.htm
I have found that some of the older DEI alarms may not program with the XK Loader3, but will program with the bitwriter.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
