Second LED Warning Light, Viper 5706v
keggerram
Posted: February 03, 2020 at 10:42 PM / IP Logged Link to Post Post Reply Quote keggerram
Quick question for the gurus here! I have a 2016 ram 1500 with a viper 5706v remote start and alarm system. The led is on the control center. My question is about adding a second warning led. The control center is at the front center of the windshield but is barely noticeable. I'd like to add a second led to say the driver side door or even the back window. Is there a way I can tap into the six pin harness that the control center is attached to? Or is there an easier way? Basically I'd like it to show that the doors are locked.
Thanks in advance for any advice tips and or tricks!!!
Craig Martin
iskidoo
Silver - Posts: 1,040
Posted: February 03, 2020 at 11:31 PM / IP Logged Link to Post Post Reply Quote iskidoo
You can use the ground when armed output from the alarm to power an add on unit like the Directed 629L. One wire goes to constant fused 12v and the other wire to the GWA output from the alarm.
Steve G
iskidoo
Posted: February 03, 2020 at 11:39 PM / IP Logged Link to Post Post Reply Quote iskidoo
Viper 620V would be a good choice too for the rear window.
https://www.amazon.com/vdp/10ea833527de4fd1b46ca117cfea959f
Steve G
keggerram
Posted: February 04, 2020 at 1:34 PM / IP Logged Link to Post Post Reply Quote keggerram
Iskidoo, thank you! Now I assume that any flashing LED would work correct? I like the 620v that you posted. I assume the positive side is connected to the orange wire on the white six pin and the other wire is connected to the constant fused 12v. If it's honestly this easy, I wonder why the installer was saying that it was a real pain to do.
Craig Martin
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
