Pac 35 vs LC2i
musclesoh92467
Member - Posts: 17
Posted: February 11, 2020 at 10:50 PM / IP Logged Link to Post Post Reply Quote musclesoh92467
Would I get by just fine using the pac 35 line out I nstead of the LC2i? I’ve always had luck with pac 35 but seen lots use the LC2i
mgoetz74
Silver - Posts: 424
Posted: February 12, 2020 at 3:32 PM / IP Logged Link to Post Post Reply Quote mgoetz74
yes and no. The lc2 has a bunch of benefits like the acubass and the input matching from the factory head unit and so on. Your not really comparing apples to apples with the two different locs. I always recommend the lc2 in newer cars especially luxury cars or ones that have factory amps (bose,infinity,jbl,dimesons,ect). If you have a old 90's car or a plain jane Hyundai or Honda and adding a sub amp, them yes the pac 35 will do just fine.
musclesoh92467
Member - Posts: 17
Posted: February 12, 2020 at 5:38 PM / IP Logged Link to Post Post Reply Quote musclesoh92467
Ok thanks and do you happen to know the color of rear speaker wires ?
geepherder
Platinum - Posts: 3,668
Posted: February 13, 2020 at 4:56 AM / IP Logged Link to Post Post Reply Quote geepherder
... for what vehicle?
musclesoh92467
Member - Posts: 17
Posted: February 13, 2020 at 10:12 AM / IP Logged Link to Post Post Reply Quote musclesoh92467
2016 v6 mustang
mgoetz74
Silver - Posts: 424
Posted: February 13, 2020 at 10:37 AM / IP Logged Link to Post Post Reply Quote mgoetz74
with amp-
Left Front Speaker - With Amp     White - White/Brown (low); Green/Blue - Gray/Blue (mid/high)     +,-     Amplifier above driver kick, gray 16 pin plug, pins 14 - 13 (low); 14 pin plug, pins 8 - 9 (mid/high)
Right Front Speaker - With Amp     White/Violet - White/Orange (low); Violet/Gray - Yellow/Gray (mid/high)     +,-     Amplifier above driver kick, gray 16 pin plug, pins 6 - 5 (low); 14 pin plug, pins 4 - 5 (mid/high)
Left Rear Speaker - With Amp     White/Green - Brown/Yellow     +,-     Amplifier above driver kick, gray 16 pin plug, pins 16 - 15
Right Rear Speaker - With Amp     Brown/White - Brown/Blue     +,-     Amplifier above driver kick, gray 16 pin plug, pins 8 - 7
without amp-
Left Front Speaker (+/-)     White - White/Brown or Green - Gray     +,-     Radio, black 24 pin plug, pins 22 - 10
Right Front Speaker (+/-)     White/Violet - White/Orange or Violet - Yellow     +,-     Radio, black 24 pin plug, pins 23 - 11
Left Rear Speaker (+/-)     White/Green - Brown/Yellow or Green/White - Brown     +,-     Radio, black 24 pin plug, pins 21 - 9
Right Rear Speaker (+/-)     Brown/White - Brown/Blue or Violet/White - Blue     +,-     Radio, black 24 pin plug, pins 24 - 12
Tuesday, June 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
