2014 Kia Soul Automatic Remote Starter/Alarm/Bypass
outcold84
Posted: October 25, 2020 at 6:12 PM / IP Logged Link to Post Post Reply Quote outcold84
Hello, looking for remote start/alarm wiring info for 2014 Kia Soul, automatic transmission, key fob will be bypassed with idatalink alca.
Thanks!
geepherder
Platinum - Posts: 3,668
Posted: October 25, 2020 at 8:14 PM / IP Logged Link to Post Post Reply Quote geepherder
http://diagrams.--/printlist.aspx?MakeID=26&ModelID=20597
wirewise
Moderator - Posts: 489
Posted: October 25, 2020 at 8:16 PM / IP Logged Link to Post Post Reply Quote wirewise
SOUL     2014-2016
KEY     T-HARNESS     IMMOBILIZER
N/A     N/A     MAY HAVE TRANSPONDER TYPE IGNITION KEYS, CHECK OWNERS MANUAL. VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE DBALL2 INTERFACE FOR REMOTE STARTING SEE NOTE #1
PART     COLOR     LOCATION     DIAGRAM
12 VOLT CONSTANT     RED (+)     IGNITION SWITCH,BLACK 6 PIN PLUG, PIN 1
STARTER     GREEN (+)     IGNITION SWITCH,BLACK 6 PIN PLUG, PIN 3
STARTER 2     N/A
IGNITION 1     PINK (+)     IGNITION SWITCH,BLACK 6 PIN PLUG, PIN 2
IGNITION 2     N/A
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     WHITE (+)     IGNITION SWITCH,BLACK 6 PIN PLUG, PIN 2
ACCESSORY/HEATER BLOWER 2     BLUE (+)     IGNITION SWITCH,BLACK 6 PIN PLUG, PIN 6
KEYSENSE     WHITE/ORANGE (-)     IGNITION KEY SWITCH, WHITE 6 PIN PLUG, PIN 4
PARKING LIGHTS ( - )     PINK (-)     @ HEADLIGHT SWITCH, WHITE 13 PIN PLUG, PIN 2
PARKING LIGHTS ( + )     GREEN/BLACK (L) (+) & BROWN/BLACK (R) (+)     DASH FUSE BOX, BLACK 16 PIN PLUG(A), PINS 9,10
POWER LOCK     RED (+)     DASH FUSE BOX, WHITE 16 PIN PLUG(B), PIN 8
POWER UNLOCK     YELLOW/BLACK (-) Type "B"     DASH FUSE BOX, WHITE 16 PIN PLUG(B), PIN 3
LOCK MOTOR WIRE     GRAY (5-WIRE TYPE)     DASH FUSE BOX, BLACK 16 PIN PLUG(C), PIN 35
DOOR TRIGGER     YELLOW/ORANGE (-)     DASH FUSBOX, WHITE E 16 PIN PLUG(B), PIN 9
DOMELIGHT SUPERVISION     YELLOW/BLACK (+)     driver front pillar, white 30 pin plug, pin 16
TRUNK RELEASE     GREEN (-)     DASH FUSBOX, WHITE 16 PIN PLUG(B), PIN 11
SLIDING POWER DOOR     N/A
HORN     WHITE (-)     driver kick, white 58 pin plug, pin 44
TACH     GREEN, (AC)     CAM POS. SENSOR, DRIVERS SIDE of ENGINE BLACK 3 PIN PLUG, PIN 2
WAIT TO START LIGHT     N/A
BRAKE     GRAY (+)     driver kick, white 58 pin plug, pin 11
FACTORY ALARM DISARM     N/A
ANTI-THEFT     MAY HAVE TRANSPONDER TYPE IGNITION KEYS, CHECK OWNERS MANUAL. SEE NOTE #1
NOTES
NOTE #1 IF VEHICLE HAS TRANSPONDER TYPE ANTI-THEFT SYSTEM , A 791 BYPASS AND EXTRA KEY IS NEEDED (TO LEAVE IN BYPASS TO SUPPLY CODE). VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE DBALL2 INTERFACE FOR REMOTE STARTING
~wirewise~ Verify all wiring with your meter before making any connections!
outcold84
Posted: November 28, 2021 at 3:45 PM / IP Logged Link to Post Post Reply Quote outcold84
Does anyone know the wire and polarity for driver heated seat to be connected to an auxiliary output?
normalicy
Member - Posts: 48
Posted: August 17, 2023 at 6:49 PM / IP Logged Link to Post Post Reply Quote normalicy
Since I haven't found it anywhere, I was able to find that the door trigger on the base model isn't just the YELLOW/ORANGE wire as stated above. That is just the driver's door trigger. I've heard that there's a single door trigger at the BCM, but I didn't find that to be the case. Maybe on higher end models? Here is the correct door trigger information:
LEFT FRONT - DOOR TRIGGER     YELLOW/ORANGE (-)     DASH FUSBOX, WHITE E 16 PIN PLUG(B), PIN 9
RIGHT FRONT - DOOR TRIGGER     YELLOW/ORANGE (-)     DASH FUSBOX, WHITE E 16 PIN PLUG(B), PIN 12
LEFT REAR - DOOR TRIGGER     WHITE/BLACK (-)          DASH FUSBOX, WHITE E 16 PIN PLUG(B), PIN 7
RIGHT REAR - DOOR TRIGGER     ORANGE (-)          DASH FUSBOX, WHITE E 16 PIN PLUG(B), PIN 5
You will need to combine all door trigger wires together to get a single trigger. You will need to use a diode on each wire. Stripe goes toward the factory harness.
What is normal anyway???
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
