2015 Toyota Tundra Crewmax Limited, Windows and Sunroof
brianh
Silver - Posts: 516
Posted: January 31, 2021 at 10:44 AM / IP Logged Link to Post Post Reply Quote brianh
Has anyone used a timer and a relay to close/ open the front windows and sunroof by tapping the wires at the driver door? If so what was your set up for closing and also for rolling down.   Thanks in adavance. Brian
brianh
Silver - Posts: 516
Posted: January 31, 2021 at 2:36 PM / IP Logged Link to Post Post Reply Quote brianh
Anyone?
brianh
Silver - Posts: 516
Posted: February 21, 2021 at 2:43 PM / IP Logged Link to Post Post Reply Quote brianh
I can put my key in driver door and hold to lock position , thus rolling both front windows and closing sunroof. I’m looking to put a two window roll up module on the rear windows and a module on the rear window as well. I will be using the orange( ground out while armed) output to control. What’s the best way to send a timed ground output for about 10 seconds to the wire at the driver door key switch to make this happen?
Thanks in advance, Brian
cpalmer
Copper - Posts: 109
Posted: February 21, 2021 at 7:43 PM / IP Logged Link to Post Post Reply Quote cpalmer
Which unit are you using? Some of the newer remote start alarms have the option to trigger wires with timers built in to the unit.
brianh
Silver - Posts: 516
Posted: February 21, 2021 at 8:02 PM / IP Logged Link to Post Post Reply Quote brianh
I just installed a Excalibur RS-475-3D. It has a trunk pop channel and a programmable channel. The wires for factory arm/ disarm can be programmed for channels 4 and 5 but no timer option. I’m guessing I will have to use a TR7 timer or the DEI pulse timer to make this happen.
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
