2005 Toyota Highlander, Remote Start/Alarm, Door Lock Wiring
admays18
Posted: December 28, 2021 at 12:06 AM / IP Logged Link to Post Post Reply Quote admays18
I've recently started to install a Compustar CM-900AS in a 2005 Toyota Highlander and have been trying to figure out how to get the locks to work. I've looked at the wiring diagram and it has helped out but for the life of me I can figure out how the door locks need to be wired. I've tried to wire both lock and unlock to relays but with no avail. Anyone know how and what I'm doing wrong?
lectricguy
Copper - Posts: 359
Posted: January 06, 2022 at 10:31 AM / IP Logged Link to Post Post Reply Quote lectricguy
Check the downloads section for Tech Tip 1070.
https://www.the12volt.com/installbay/downloads.asp?srch=all&term=tech+tip+1070
Power Lock     (use factory alarm arm)
Power Unlock     (use factory alarm disarm)
Factory Alarm Arm     gray (passenger door key lock); brown (detection) (see Tech Doc 1070)     - and open     passenger kick, white 14 pin plug, pins 1, 2
Factory Alarm Disarm     violet (passenger door key unlock); brown (detection) (see Tech Doc 1070)     both -     passenger kick, white 14 pin plug, pins 8, 2
That should clarify how the locks need to be wired.
Lectric Guy
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
