2020 Ford Mustang With OEM Sub, New Subs And Amp, Popping Sound
ramon2001
Member - Posts: 47
Posted: August 18, 2022 at 12:33 PM / IP Logged Link to Post Post Reply Quote ramon2001
added two ten inch kicker subs with amp. tapped into oem sub using blaukpunkt hi-lo converter with remote turn on. the subs keep making popping sound after car is turn off. convertor stays on. any suggestions on what to do. thank you for your help.
ramon
Platinum - Posts: 13,725
Posted: August 18, 2022 at 7:43 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Disconnect the wires from the factory subwoofer. Leave the converter where it is connected, just unplug the OEM sub.
ramon2001
Member - Posts: 47
Posted: August 19, 2022 at 12:35 PM / IP Logged Link to Post Post Reply Quote ramon2001
it is disconnected. i was told its the ANC module that needs to be disconnected. does anyone know the location of it? thank you very much. please help with suggestions. this has been so stressful
ramon
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
