2011 Mercedes Sprinter, Alarm Security Diagram
mazda 6t9
Member - Posts: 33
Posted: October 11, 2022 at 10:42 AM / IP Logged Link to Post Post Reply Quote mazda 6t9
2011 Mercedes Sprinter alarm security diagram please. Thank you in advance
mgoetz74
Silver - Posts: 424
Posted: October 12, 2022 at 3:56 PM / IP Logged Link to Post Post Reply Quote mgoetz74
this is security only, no remote start
12 Volts     red (150A)     +     fuse/relay box, rear, black 3 pin plug, pin 1
Second 12 Volts     red/gray (25A); red/gray (10A)     +     ignition switch, black 5 pin plug, pin 1; white/black 8 pin plug, pin 8
Ground     (chassis ground)
Starter     violet (for starter kill only)     +     fuse/relay box, rear, black 18 pin plug, pin 1
Ignition     black     +     ignition switch, black 5 pin plug, pin 2          Notes
CAN Bus High     brown/red     data     BCM on fuse/relay box in driver kick, 52 pin plug (C9), pin 51
CAN Bus Low     brown     data     BCM on fuse/relay box in driver kick, 52 pin plug (C9), pin 52
Power Lock     (use the motor wires)     5 wire
Power Unlock     (use the motor wires)     5 wire
Lock Motor     dk. blue/red     5 wire     Driver Door Module, black 20 pin plug, pin 12
Driver Unlock Motor     dk. blue/black     5 wire     Driver Door Module, black 20 pin plug, pin 11
Passenger Unlock Motor     dk. blue/black     5 wire     BCM on fuse/relay box in driver kick, 52 pin plug (C9), pin 48
Factory Alarm Arm     (factory remote only)
Factory Alarm Disarm     (factory remote only)
Disarm No Unlock     (transponder and keysense)
Parking Lights     gry/bk (LF), gry/rd (RF); gry/bk (LR), gry/rd (RR)     +     BCM, 52 pin plug (C9), pins 23, 9; 20 pin plug (C3), pins 1, 12
Hazards     (CAN bus)
Turn Signal (Left)     black/white (F); black/white (R)     +     BCM, 52 pin plug (C9), pin 13; 20 pin plug (C3), pin 15
Turn Signal (Right)     black/dk. green (F); black/dk. green (R)     +     BCM, 52 pin plug (C9), pin 24; 20 pin plug (C3), pin 16
Headlight     yellow/black (L); yellow/red (R)     +     BCM on fuse/relay box in driver kick, 12 pin plug (C7), pins 10, 4
Left Front Door Trigger     dk. blue/dk. green     -     Driver Door Module, black 20 pin plug, pin 8
Right Front Door Trigger     dk. blue/dk. green     -     BCM, 52 pin plug (C9), pin 43
Left Rear Door Trigger     yellow/white     -     BCM, 52 pin plug (C9), pin 4
Right Rear Door Trigger     pink/white     -     BCM, 52 pin plug (C9), pin 41
Dome Light     brown/dk. green     -     BCM on fuse/relay box in driver kick, 18 pin plug (C6), pin 1
Trunk/Hatch Pin     dk. blue/dk. green     -     BCM on fuse/relay box in driver kick, 20 pin plug (C3), pin 6
Hood Pin     brown/pink     -     hood switch, 2 pin plug, pin 1
Power Sliding Door (Left)     yellow/dk. green     -     left B pillar sliding door sw, 3 pin plug, pin 2
Power Sliding Door (Right)     gray/dk. green     -     right B pillar sliding door sw, 3 pin plug, pin 2
Tachometer     yellow/gray     ac     camshaft position sensor or ECM on dr fender, blk 96 pin plg, pin 33
Fuel Pump     red/dk. green     +     fuse/relay box, rear, blk 14 or 18 pin plug, pin 2
Horn Trigger     dk. green     +     fuse/relay box, rear, black 18 pin plug, pin 16
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
