Compustar CM2500 Full Installation Guide
scottl547-413
Posted: January 19, 2023 at 5:01 PM / IP Logged Link to Post Post Reply Quote scottl547-413
Hello 12volt wizards. Thank you for allowing me into your group. I'm in desperate need of the Compustar Full installation guide pertaining to the CM2500 alarm control module. I do have the basic wiring schematic that came with the CS852a Bundle I purchased. Included was Shock, 4 pin Antenna, FT-Elock. I have no intention to use the remote start, door/trunk lock features.
I did find the Jeep wiring information in this group. Thank You!
I'm partially through my install of this product in my 1999 Jeep Wrangler Sport. I did not use the white 3 wire relay connector w/fuse (labeled CN1), or the white 6 pin/4 wire, lock/trunk release harness (labeled CN3), or the DM600 harness. After Programing the remotes as directed in the materials inside the box. I can only hear the internal (Relays?) click 3 times out of the CM2500 module, that's it. One time per install/removal of the fuse.
I'm fairly confident that with the full install materials for this unit I can trouble shoot what I have done wrong. I am running out of time to remove and return this product for some type of refund or credit from the seller. Thank you in advance for your time! Compustar CM2500 Full Installation Guide - Last Post -- posted image.
Scott-Kitt
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
