2010 Ford Fusion, iDataStart 3.5/HCA320
Platinum - Posts: 7,791
Posted: June 11, 2023 at 5:46 PM / IP Logged Link to Post Post Reply Quote kreg357
Do you get the Parking Lights with a R/S?
The Parking Lights should work fine using that Purple/White wire at the BCM Gray 13 Pin connector. Use your DMM to verify that wire and then the +12V relay output. The White/Black (-) Parking Light Output wire is not a POC so no issues there. You could test it with a DMM to check for it's (-) output during R/S runtime and
with the lock commands.
As far as options that affect this, check :
1-20 should be set to F02 (default).
2-17 should be set to F02 (default).
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
