Alpine Amplifier
sabean
Member - Posts: 16
Posted: March 25, 2025 at 11:02 PM / IP Logged Link to Post Post Reply Quote sabean
So I have this alpine amp and it will only turn on it I have a jumper wire going to 12 volt power terminal. I don’t have any 12 volt on a meter between power and ground until that jumper is put into place. Any thoughts?
Paul hoffman
lee.lopez
Copper - Posts: 307
Posted: March 26, 2025 at 1:53 AM / IP Logged Link to Post Post Reply Quote lee.lopez
What is the amp (I see it's Alpine but what model number)? You mentioned it won't turn on without a jumper in place but no details about where the jumper is (from where to where- what terminals?).
Do you have any pictures? Is this installed on a vehicle? Are you bench testing it?
sabean
Member - Posts: 16
Posted: March 27, 2025 at 12:24 AM / IP Logged Link to Post Post Reply Quote sabean
The jumper wire is going from 12 volt power to the remote terminal. Yes it’s wired up in a car and works great I’m just trying to figure out why because when doing this the amp will stay on all the time
Paul hoffman
lee.lopez
Copper - Posts: 307
Posted: March 27, 2025 at 4:40 AM / IP Logged Link to Post Post Reply Quote lee.lopez
You have not told us the model number of the amplifier. Troubleshooting is more difficult without all the information.
You said you don't measure 12 volts across the power and ground on a meter until that jumper is in place. Is this "meter" a digital display in the amp itself or a multimeter? Have you done a continuity check of the main fuse?
Have you measured voltage between the remote terminal and ground with the source unit on? If so, what were your results? Where is the remote turn on wire connected? Have you done a continuity check between the remote terminal and your connection?
How long have you had this problem? Did it just start after some work was done? If so, a panel could have pinched the remote wire causing a break. Is this a new install?
forbidden
Platinum - Posts: 5,354
Posted: August 29, 2025 at 10:29 PM / IP Logged Link to Post Post Reply Quote forbidden
The remote terminal is designed to turn the amplifier on and off when the ignition or radio is on. This line needs +12 volts from the radio that sends out +12v when the radio is turned on (some radios have remote on and a separate power antenna line, use the remote on). In the event your radio does not have this line, run a ignition line to the amp that supplies +12 volts when the ignition is turned to on.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
