Wiring for 2003 Honda Pilot
Fobin
Member - Posts: 25
Posted: August 06, 2003 at 10:23 AM / IP Logged
Looking for wiring for the Honda Pilot for remote start. Also, any recomendations for a good remote starter for the vehicle.
Moderator - Posts: 12,488
Posted: August 06, 2003 at 11:02 AM / IP Logged
2 way or one way systems ?
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|blue/green *1       |-  |passenger mux unit *2       |
|     POWER UNLOCK|BLACK/ red *1        |-  |passenger mux unit *2       |
|       LOCK MOTOR|WHITE/ blue          |   |passenger mux unit *2       |
|     UNLOCK MOTOR|yellow              |   |passenger mux unit *2       |
|    DISARM DEFEAT|lt. GREEN/ red       |   |passenger mux unit *2       |
| PARKING LIGHTS +|RED / black           |   |driver kick panel           |
| PARKING LIGHTS -|RED / yellow          |   |headlight switch            |
|       HEADLIGHTS|blue/black          |-  |headlight switch            |
|     DOOR TRIGGER|BLACK/ white         |-  |interior light switch       |
| DOME SUPERVISION|lt. green           |-  |interior light switch       |
|  TRUNK/HATCH PIN|common with doors   |   |                            |
|         HOOD PIN|yellow              |-  |hood switch or *3           |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blue                |-  |driver door key cylinder    |
|       TACHOMETER|blue                |   |tach test connector *4      |
|      SPEED SENSE|blue/white          |   |cruise control actuator *5  |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|+  |steering column             |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |driver window motor in door |
|  RF WINDOW UP/DN|blu/wht - blu/red   |A  |RF window switch in door    |
|  LR WINDOW UP/DN|blu/wht - blu/red   |A  |LR window switch in door    |
|  RR WINDOW UP/DN|blu/wht - blu/red   |A  |RR window switch in door    |
|        RADIO 12V|white               |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ red           |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|yellow/white        |+  |radio                       |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht *6|   |radio                       |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U.  *1 Meter these wires while turning the key in the passenger door key cylinder.  *2 The passenger mux unit is attached to the passenger side fuse box in the passenger kick panel.  *3 Also found at the driver mux unit, which is attached to the driver side fuse box in the driver kick panel.  *4 The tach test connector is a 2 pin connector on the driver side fender.  *5 The cruise control actuator is behind the passenger side headlight.  *6 The subwoofer is in the RR side panel. It is powered by the radio in the dash. The wire colors are WHITE/ green (+) and BLACK/ white (-).
Fobin
Member - Posts: 25
Posted: August 06, 2003 at 11:33 AM / IP Logged
Thanks for the info. I guess I would only want one way. I don't see any reason to get info back from the car. But, if the price is right, why not two way.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
