2002 Saturn SL1 Alarm/Remote Start/Stereo Wiring
newfie
Posted: November 14, 2003 at 10:04 PM / IP Logged
a freind gave me a prostart car starter package but before I put it into my car i want the  wire diagram for my 2002 saturn's wire harness
Thanks, Newfie
v8fiero
Member - Posts: 10
Posted: November 14, 2003 at 11:57 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V     |red                          |+ |     ignition harness            |
|     STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|green               |+ |ignition harness            |
|   THIRD IGNITION|lt grn (key sense)*7|- |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
| SECOND ACCESSORY|brown               |+ |ignition harness            |
|       POWER LOCK|ORANGE / black        |+ |drivers kick panel          |
|     POWER UNLOCK|RED / black           |+ |drivers kick panel          |
|       LOCK MOTOR|gray               |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |steering column             |
|       HEADLIGHTS|blue *6             |- |steering column             |
|     DOOR TRIGGER|*1                  |- |*2                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / black           |- |BCM, gray 24 pin plug *2    |
|TRNK/HTCH RELEASE|black               |+ |switch *4                   |
|       TACHOMETER|*3                  |   |*3                          |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|lt blue             |+ |brake switch               |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|green(L), purple(H) |+ |steering column             |
| LF WINDOW UP/DN|dk blue - brown     |A |switch in center console    |
| RF WINDOW UP/DN|blue - brown        |A |switch in center console    |
| LR WINDOW UP/DN|dk green - purple   |A |switch in center console    |
| RR WINDOW UP/DN|lt green - purple   |A |switch in center console    |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|   SUN ROOF LIMIT|not recommended     |   |                            |
|        RADIO 12V|orange              |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|yellow              |+ |radio                      |
| RADIO ILLUMINATE|brown               |+ |radio                      |
|       LF SPEAKER|tan - gray          |   |radio or amplifier *5       |
|       RF SPEAKER|lt green - dk green |   |radio or amplifier *5       |
|       LR SPEAKER|brown - yellow      |   |radio or amplifier *5       |
|       RR SPEAKER|dk blue - lt blue   |   |radio or amplifier *5       |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The drivers door is gray/black. The other doors are BLACK/ white. Both wires are in the gray 24 pin plug at the BCM. Use both wires and diode isolate each. *2 The BCM is located above the glove box. *3 On the 4 cylinder models, use PURPLE / white at the ignition module on the driver side of the motor. On the 6 cylinder models, at the ignition coils on top of the cylinder head on the drivers side of the motor, use any one of the three wires that is not pink or black. *4 Can also use BLACK/ white (+) at the BCM in the gray 24 pin plug. *5 The amplifier in under the driver side dash above the brake pedal. *6 Low beam is high current negative, must use relay. *7 The lt. green key sense wire at the steering column must see a ground during remote start to keep the "SERVICE" light from coming on.
Wednesday, June 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
