current draw of LEDs
Pooreclipse
Copper - Posts: 75
Posted: April 30, 2004 at 12:11 PM / IP Logged
I have a couple of LEDs I want to hook up for "domelight supervision"
This is the specs here.
http://www.superbrightleds.com/T13_specs.htm
If I understand correctly each LED draw 40 mA ? (forward current..??)  My domelight wire is low output and only 200mA.
BTW.  What is the correct way to hook up 2 of these LEDs.
If you just joint the ground and + together on each LED, wouldn't only one go on at a time?
eurotech
Member - Posts: 44
Posted: April 30, 2004 at 12:59 PM / IP Logged
hook your domelight supervision output to a relay, I imagine that it is a negative output- then send a full 12 volts to your led's.  if you hook them up in parallel (as mentioned) they should both come on at the same time.  Good luck!
Pooreclipse
Copper - Posts: 75
Posted: April 30, 2004 at 1:02 PM / IP Logged
I know.. but I am trying to save a relay (less wiring) because if I don't have to, why bother?
It sounds like the draw is 40 mA and the output can support 200 mA... two LEDs take 80mA only, right?
capple
Member - Posts: 25
Posted: April 30, 2004 at 1:20 PM / IP Logged
Yes I would go ahead and hook it up as you want to. You are correct in that the total current is 80mA
mikej9881
Member - Posts: 20
Posted: April 30, 2004 at 2:32 PM / IP Logged
most outputs from alarms for domelight supervision is a negative output so you have to use a relay to convert polarity. unless maybe you power the leds and then hook the ground side straight to the negative output of the alarm but ive never done that so.....
mike
Pooreclipse
Copper - Posts: 75
Posted: May 03, 2004 at 3:46 AM / IP Logged
Ok, I have made a relay for it anyway.
My question is, I have merged the 12V and ground wire for both LEDs at one point,
so they are in parallel.
My question is wouldn't my LEDs now become half as bright?? since they share the current in parallel?
capple
Member - Posts: 25
Posted: May 05, 2004 at 2:22 PM / IP Logged
Simply stated NO the main power wire will have 80mA the branch circuts will have the 40mA each.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
