Fiberglass Mat Weight
Spaceman Spiff
Member - Posts: 28
Posted: May 18, 2004 at 1:52 PM / IP Logged
I see plenty of threads about "How many layers should I use?" and generically it 5-7 and >= 3/8"s thickness, but no one ever mentions the weight of the mat or cloth. I have been using .75 and 1.5 ounce mat but to get to ~.25" it has taken about 6 layers, maybe more. So I have to ask what weight mat/cloth is being recommended for 5-7 layers and a thickness > 3/8's?
Spaceman Spiff
Member - Posts: 28
Posted: May 18, 2004 at 3:25 PM / IP Logged
After doing a bit more refined a search, I found one post that recommended 8oz.
stormshadow
Member - Posts: 34
Posted: May 18, 2004 at 9:22 PM / IP Logged
In boat building we use multiple layers which are offset arround 35 degrees from the previous layer. This provides additional strength. I don't think, however, that in this instance you would see any real benifit.
Stormshadow
audiomechanic
Silver - Posts: 388
Posted: May 19, 2004 at 7:02 AM / IP Logged
most people use 1.5 oz because it is the easyiest to find.......the thickest i would use is 3 oz. even that can be hard to bend in certain contours and corners. the thicker the mat the more difficult to soak it all the way thru.
Spaceman Spiff
Member - Posts: 28
Posted: May 19, 2004 at 9:14 AM / IP Logged
Audiomechanic, how many layers of 1.5 would then be needed for reasonable thickness. I've been using 1.5 and roughly 6 layers amounts to about a 1/4" which seems to be contrary to what many here say. So then are we talking ~12 layers rather than 6-7 for a reasonable non-flexing enclosure. Correct or incorrect?
defective
Silver - Posts: 642
Posted: May 19, 2004 at 9:49 AM / IP Logged
i usually use about 6 layers of 1.5 then i use duraglass to fill in all the holes and smooth it out. makes the inside of a tirewell nice and smooth, plus it makes the thickness the same thoughout the enclosure.
Spaceman Spiff
Member - Posts: 28
Posted: May 19, 2004 at 3:06 PM / IP Logged
So defective 6 layers of 1.5oz + lets say about a centimeter of duramix is sufficient for a solid fg enclosure. I continue to ask because my first attempt has been reasonably successful but thickness is questionable and I'd hate to have to start again due to the glass being to thin.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
