2003 F-150 Super Crew
Welcome Guest :)
DaveK
Member -
Posted: June 08, 2004 at 2:26 PM / IP Logged
I'm looking for a wiring diagram for a 2003 F-150 Super Crew. Specifically the wiring for the power windows on all 4 doors.
Thanks.
jfk51502003
Copper -
Posted: June 10, 2004 at 5:06 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2003 / Accessory [PRINT THIS PAGE] 12volts | yellow & lt. GREEN/ purple | + | ignition harness | Ignition | dk. blue/lt. green | + | ignition harness | Parking Lights+ | brown | + | headlight switch | Notes: May also be found at the trailer connector next to the diagnostic connector under dash. | Parking Lights- | lt. GREEN/ YELLOW | - | headlight switch | Notes: If equipped with autolamps. | Headlight | RED / yellow | + | headlight switch | Trunk/Hatch Release | N/A | | | Power Sliding Door | N/A | | | Speed Sense | | | | Wipers | | | | LF Window up/dn | ORANGE / white - WHITE/ black | A | driver window motor | RF Window up/dn | WHITE/ yellow - tan/lt. blue | A | driver kick, door harness | LR Window up/dn | | | | RR Window up/dn | | | | Sun Roof open/close | | | | Sun Roof Limit/close | | | | Memory Seat 1 | | | | Memory Seat 2 | | | | Memory Seat 3 | | | | Immobilizer Bypass Module: | Required: Yes | Type: PATS | Part #: 555F or 555U | Notes: N/A |
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. |
DaveK
Member -
Posted: June 13, 2004 at 9:40 PM / IP Logged
Thanks. Any information on the other two windows?
Sunday, June 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
