Cap/HO alternator
Herald
Member - Posts: 46
Posted: August 12, 2004 at 7:15 PM / IP Logged
  Hi i have  a cap and yellow top  im running about 700watts nominal rms (400 sub, 280 others). Do i need a high output alternator? after how many watts do you need a HO  ALT? thanks
A person who carries or proclaims important news; a messenger.
Alpine Guy
Platinum - Posts: 2,478
Posted: August 12, 2004 at 9:33 PM / IP Logged
Are your lights dimming?  Whats the fuse rateing combined on all your amps?  What kind of car?
Herald
Member - Posts: 46
Posted: August 14, 2004 at 12:54 PM / IP Logged
well the lights are  dimming a  little but is it possible that it alittle because the batery is new. will this be a prob in the future
stevdart
Platinum - Posts: 5,816
Posted: August 14, 2004 at 3:58 PM / IP Logged
Your battery new is as good as it will ever be.  As far as lights dimming goes, experiment with this:  select a music source that has hard, loud bass hits that linger (like a lot of synthesizer bass hits). With the car engine running,  and playing the system loud, watch the lights as the bass notes hit.  If the lights flicker just briefly at the beginning of the hit, but become brighter before the note ends, then that indicates a problem with getting enough juice to the amp quick enough.  This is normally corrected with a cap, which would provide a quicker response.  But if the lights stay dimmed during the complete bass hit, that indicates that the alternator is not capable of supplying enough current to meet demands.
Jay T
Copper - Posts: 169
Posted: August 14, 2004 at 9:11 PM / IP Logged
Depends what your stock alternator puts out. and what condition its in.  Go to a shop and have them test your charging system.  Your battery is ok, so they can see if your alternator is putting out enough juice under load.
Herald
Member - Posts: 46
Posted: August 15, 2004 at 10:28 PM / IP Logged
i think ill get the ho alt thanks
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
