relays in parallel
snooptodd
Posted: August 23, 2004 at 11:05 PM / IP Logged
Can 2 30A relays be wired in parallel to get greater output?
auex
Platinum - Posts: 5,041
Posted: August 23, 2004 at 11:10 PM / IP Logged
How much power do you need? It may be worth buying a heavy duty solenoid.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
HotRod53F100
Copper - Posts: 84
Posted: August 24, 2004 at 6:06 PM / IP Logged
A solenoid or higher rated relay may be a better choice, but you can double (2) 30 amp relays to get a 60 amp capacity. How about a multi-pole relay with all poles parallelled? Remember a 3 pole 30 amp relay is 30 amps per pole.....2 poles paralleled = 60 amps.
xetmes
Silver - Posts: 586
Posted: August 24, 2004 at 8:23 PM / IP Logged
you would be better off with a higher current switching device (as stated) switching time differences will lead to one of the relays carrying all the current, may never cause problems though...
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
